20160603_111031.jpg the rectangular-ish airbox connected to the air link in with an L shaped hose?????
What is this air intake part and what does it do?
This person got rid of the rectangular airbox.
What's the ramifications though? What does that box do?
I could be totally wrong, but I think it is an air box muffler and there are no issues without using it.Rick
1993 Ford Festiva
1986 AMC Eagle Wagon 4.2L/4.0L head, AW4,NP242, Chrysler 8.25" rear. SOLD
1981 AMC Eagle Wagon-As Seen on TV Lost In Transmission
2000 Ford E350
i'm pretty sure you are right, it just reduces intake noise without adding restriction. I've never had any problems with taking them off.Originally posted by Eaglefreek View PostI could be totally wrong, but I think it is an air box muffler and there are no issues without using it."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
+1, get rid of it with no worries. Cleans up the engine bay a bit.Originally posted by firebush357 View Posti'm pretty sure you are right, it just reduces intake noise without adding restriction. I've never had any problems with taking them off.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
How much torque can you really lose on a Festiva though? Google says we only have 73 to begin with.Last edited by firebush357; 06-03-2016, 01:55 PM."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Which you can simply and inexpensively get back by merely adding a Dickmeyer-prepared head and 4-1 exhaust header.....Originally posted by Dragonhealer View PostHate to rain on everyones parade.
Run your car on a Dyno, remove hose to ballance chamber, plug off hole in intake, retest.
Compare the two Dynographs to see where you lost torque, and how much !
Last edited by TominMO; 06-03-2016, 02:03 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Interesting. Do you have any info on this? I searched the net and the only balance chamber info I could find was for a dirt bike. Does it go by another name?Originally posted by Dragonhealer View PostHate to rain on everyones parade.
Compare the two Dynographs to see where you lost torque, and how much !Rick
1993 Ford Festiva
2000 Ford E350
Another name may be resonance chamber, it has to do with the volume and dynamics of the intake plenum. It eliminates a torque drop of about 3% at or just before torque peek. Still looking for that dyno test we did 2 years ago...Originally posted by meyek91974 View PostDragonhealer, I did a Google search for a 1990 Ford Festiva air intake balance chamber and I cannot find information describing what it does how it works and so on. Can you explain further what it does or how it works and do you have a link to a page or anythingNo car too fast !
The dotted line is first pull with chamber in place, solid line chamber blanked off.
the difference between the two lines is due to heat soak, but you can clearly see a loss of torque where the " horsepower " line crosses the torque line.
Thanks Tom, that's true
Looks like it won't upload the pic from my Android, 1.8Mb? Or some other glitch?
Guess I'm tech challenged !Last edited by Dragonhealer; 06-03-2016, 03:46 PM.No car too fast !
No. I fact I think the difference in torque is hard to even measure with the butt dyno.Originally posted by meyek91974 View PostI drive slow and economical. Shift at 25, 35, 45, and cruise 50-55 in 5th.
Will omitting this effect me? Will it affect mpg?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
