This is not the first time I've done this but am having a problem this time.
I bought new Kia Rio struts and strut mounts from Rockauto. I pulled the old struts off of the Festiva and started swapping over the springs when I noticed that the spring "hat" and the rubber insert in the spring hat do not seem to fit onto the strut as it should. And also when I attempt to tighten the nylon lock nut it will not tighten because the strut shaft turns. Do I need to get the spring hat from a Rio? And the rubber insert?
Thanks.
Thanks.
