Throttle Body/Intake Manifold
  • Throttle Body/Intake Manifold
    So I did some work on my brothers car the other day and took the throttle body off for cleaning, the gasket was stuck on the Intake manifold side and wasn't coming off so I grabbed a Heavy Duty Scuff wheel which worked great but I may have taken a little bit of aluminum material with it because now I have a leak even with a brand new Felpro Gasket. The amount of material I took off was minor but I may have made it uneven... So the question is, Take it apart and try to even out the surface or just double up on the gasket and see if that works?
    RTV and no gasket.
    For aluminum I never use a brush or scuff thing. Take the whole thing and work it on top of a big piece of sandpaper that is on top of a true surface. A concrete block is cheap and works fine. Then you know you end up with an even surface.
    For the big pieces only a razor blade CAREFULLY to get it to a point where I can sand it.
      I don't really want want to take the upper intake off so maybe I will make a oversize sanding block and try it that way.
        Me personally - I'm a big fan of gasket dissolver spray, and a one inch Stanley wood chisel as a scraper that I NEVER EVER use for anything else...
        (It beats even a dedicated SNAPON gasket scraper)
        Blue silicon and a single gasket ought to do the job, now that the damage is done if any. I don't think silicone sealer alone, but silicone on a gasket will make the gasket easy to remove later and the same gasket can be used over and over again.
        Most people don't drive what they want at all, and never will
          Grey: I've read silicone should not be used on cars with O2 sensors. Not true?
            They do make "O2 Sensor Safe" silicone. I would go with that.
            A mechanic knows how; A technician knows why.
            Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
            Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
            Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
            FB Festiva page: Jared Bennett
            Instagram: jaredbear82
              So I finally had time to take the throttle body off last night and realized that I actually put the gasket on wrong... it was turned 90 degrees to the right so basically the curvy part was at the bottom... ooops, I guess that might be a sign to not Drink and Mechanic lol.
                Shouldn't matter on the intake side, only the exhaust. On the intake side there is no way for silicon outgassing to interfere with O2 sensor readings.
