Hi guys, I was wondering how to replace the light bulbs inside the a/c control knob. The lights on the numerals near the knob got busted. and I can't seem to take apart the whole assembly. Is this thing sealed? Can somebody tell me how to open it. Thanks! 87788779_3_1000x700.jpg
Replacing the lights on the A/C switch control
The face of the HVAC controls will pop out with a pick once all the knobs are removed, then you can access the bulbs. Needle nose pliers with rubber covered tips should do the trick.Trees aren't kind to me...
Originally posted by FestYboy View PostThe face of the HVAC controls will pop out with a pick once all the knobs are removed, then you can access the bulbs. Needle nose pliers with rubber covered tips should do the trick.
Tiny little tabs around the edgeTrees aren't kind to me...
