5th shift fork
  • 5th shift fork
    I have a 1991 Festiva with a broken 5th shift fork. Does anyone know where to get one? Thank you.
    Which Kia part number is it?
    KK37017402 is the 1-2 fork
    KK37017404 is the 3-4 fork
    KK37017406 is the 5-R fork
    The shift fork you need is $8.57
    Good luck.
      I have a 'parts' transmission at home. I can check on the weekend to see if the fork you need is still there.
      Ian
        Thank you!!!!
          That's ok Fastivaca, bravekozak gave me the part number I need!
            sphil, you might not have to order from Four Green.
            Look up the part number at a Ford parts counter and then check Rear Counter.
              fords # is E8BZ7230D but availability don't look good.
                That's ok, thank you for all of your help. I just went ahead and ordered the shift fork from four green.
