Hi Guys, I have removed the running gear out of a WB (bubble type Festiva) and fitted to WA 3 door body and have it all running and driving (pretty simple swap). Looking for wiring diagram/pinout for the instrument clusters for the WA and WB. Can any one help? ty1
Engine swap AUS WB EFI 1.5 Engine into WA Chassis
I got scans of all my wiring diagrams from a WF workshop manual they had at the state library but I didn't get the cluster diagrams.. if I'm in the area tomorrow I might pop in and snap it for you.
are you swapping the WB cluster into your WA?? Interested in a WF blue faced tacho cluster? I'm 83% sure the wiring is identical
Those instrument clusters are very rare in the US.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
