tail light dash light problem after dash swap
  • tail light dash light problem after dash swap
    I swapped an 88 dash into my 90 festiva harness on back of dash was different so swapped 90 harness on to 88 dash everything is now together but my dash and taillights go out when I turn the headlights on. Ideas? everything worked fine before the swap and I really don't want to pull the dash back out.Which is what I am going to do unless I get some good ideas here.Thanks, I aleady searched every post I could find that were similiar but nothing that seemed to fit my scenario.
    88 had no headlight relay.
