So I have been having some issues with my Speedo. I recently took it all apart and found out that it was unplugged. I fixed it through yalls ultimate knowledge and it worked great after... for about half a day. I had drove it a few time that day but when I went to leave my moms job the Speedo was only reading like 10mph when I was doing 35ish. The speedo will move some but never to the correct amount, and then sometimes it pegs out at 85. I took apart the dash and tried to fix it again but it has never worked right since that day.
Is there a bad spring in the mechanism or something or do I need a new Speedo Cable?
I have an extra Cluster I could check with but I figured I would ask first.
Thanks!
Thanks!
