I found an exploded diagram of the manual shifter setup in a 91 ford festiva, but between that and the search box i cant seem to locate what i need.
I just got the car a couple weeks ago and have been getting it road worthy. I removed the shift knob and boot from up top and then went under to remove the bolt so i could change out the shifter. Thats when i noticed that the stabilizer rod is just hanging underneath the shifter housing by a bolt that the previous owner must have drilled through amd attached with a nut. Its super flimsy
How is the bar supposed to be connected to the bottom of the shifter housing? So i know what broke, what needs to be replaced and how to do it correctly?
