Replacing HLA in Festiva rockers
  • Replacing HLA in Festiva rockers
    I got my rebuilt head back from the machine shop yesterday and I've decided to replace the HLA s before I put the
    rockers arms back on.
    I've never done this before. Anything special I need to know.. watch out for?
    Do I just pull the old ones out and push the new ones in?
    Also.. The shop charged $299 for the complete job with parts and labor which included 4 new exhaust valves and cam seal.
    Is that a typical charge?
    Kept searching using different search criteria "lifters" and found this:
    http://www.fordfestiva.com/forums/sh...hlight=lifters
    So i guess I covered (except for price question) unless someone else wants to add some words of experience and wisdon.
    Considering the work that was done, I'd say the price is within reason (assuming deck, valve lap, clean and pressure test, new guide seals)
      Price sounds good to me actually.
      I cleaned my hla's. Just pulled em out, soaked them, pushed them back in and pumped them in a cup of oil. Worked quite well. With new ones maybe you have to soak them overnight like they said, couldnt hurt.
        They did all that in addition to the four new exhaust valves, polishing the cam and smoothed out some pitting in the #4 chamber, so I guess I got a fair deal.
        It sure looks like new. This is the original head that was on Rosie. A bit of metal had gotten into the #4 cylinder at some point and broken off edges of the piston top and also did a little pitting in the head chamber. I had offered it for sale for $30 to someone here but then decided to have it check out and rebuilt if it turned out to be OK. Now I have a good spare.
        Only a couple of the existing Hla's don't respond like they should when depressed but I though the head looked so good I would just put all new ones in. Like you say "Can't Hurt" so I will soak them overnight. before installing.
