OK guys, so after 22 hours of hard labor the new block is in and she's running great.... if the vacuum advance is plugged and i set the timing... the engine runs smooth, minus some valve chatter.... when i plug in the vacuum advance the idle goes a little knocky, if i turn on the air inside or the light and it goes to high idle it runs great, but ofcourse a little higher idle. What am I missing and please dont say a 300$ dizzy, I've had just about enough of the expensive and time consuming repairs.
Vacuum advance idles erratic
Sounds like the vac advance diaphragm is leaking. But the real question is does your vac advance have 2 ports? Or are you running the B6t unit? I ask because it doesn't say anything about upper or lower port.Trees aren't kind to me...
If I unplug the top vacuum advance hose on my car the engine dies. I know because that's the hose I pull and into which stick the vacuum guage for engine diagnosis. I have to be quick or the engine stalls and dies.
That hose should have normal vacuum about 18-22 I think it is.
Last edited by WmWatt; 09-20-2016, 07:00 PM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
