Hey guys. It's been a long time since I've been here. I blew out a ball joint a couple weeks ago. I've never had that happen to me before, but it's not a great experience. Luckily, I wasn't driving fast when it happened. That would be a bad deal if it happened at highway speeds.
Anyway, I have replaced the control arm for the side that failed without any major issues. I'm finally getting around to doing the other side today. While trying to remove the inner pivot bolt, I'm pretty sure that the nut that's welded to the frame has split. I'm guessing I could cut away part of the unibody to get to the nut so I can remove it, then just use a standard nut I suppose.
Has anyone else had this happen, and what did you do to repair?
Forgive me for saying this, but I think I'm ready to be done with Festivas. I'm not sure I even want to fix this thing anymore. This would be the end of a long era for me. I've been driving Festivas since 1993.
