I'm in middle repairing my 93 auto, which the flex plate bolts back out of and mess up flex plate and some other things anyway, I'm wondering if anyone can tell me what's a good fluid to run in this auto along with any type of additive!? Thanks
93 auto trans fluids
Regular old Dexron/Mercon III is the original spec. I was told by a super reputable person to run Ford type F fluid though as it doesn't foam as much and will firm the shifts up slightly.
I wouldn't use any sort of fancy synthetic ATF. Too slippery.91GL BP/F3A with boost
Originally posted by bhazard View PostRegular old Dexron/Mercon III is the original spec. I was told by a super reputable person to run Ford type F fluid though as it doesn't foam as much and will firm the shifts up slightly.
