Howdy, I have just acquired a 88 manual sport model FF. Im usually very good at trouble shooting and repairing stuff, however this d*mn carb is making me want to pull my hair out! Who thought it was a good idea to put a vacuum and ecu control on a carb? Once warmed up the idle is around 2500 rpm and if you tap the skinny pedal it goes higher and stays their for a while, then it starts the second act of its BS it starts to come down in rpms in steps. Then it finishes off by idle hunting until it finally stutters and stumbles and dies. If you can heel/toe it when its in it's death throws it will eventually return to the 2500 mark then repeat the process. It however runs great going down the road, seems to have plenty of pep when doing a heavy throttle pull. I moved the dist a little bit and that seemed to help with the dieseling when the ignition is turned off.
I have checked for vacuum leaks,messed with the white idle screw,the choke plate is open once warm and pulled of a vacuum hose on the carb with no change (finger o hose has suction). I'm lost and confused. I got this for a cheap beater and putting a bunch of $$$$ into this hoopty is not an option.
Thanks guys
Thanks guys
