So I decided to keep my bp festy for a little longer and want to get everything fixed. My fuel gauge does not work. I tested the wires at the sending unit and no power at all back there. Any clue where to start? If any help my temp gauge does not work either.
Fuel gauge reading empty
1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.Tags: None
I'll recheck that. I believe fuse is good but never hurt to double check.1990 Red Festiva STOCK "pregnant roller skate"
Just double checked them. All fuses are good.1990 Red Festiva STOCK "pregnant roller skate"
Check the ground for the fuel gauge. Remove the fuel pump access cover under the rear seat. Make sure power is going into the fuel level sender via the yellow wire. Make sure power comes out the fuel level sender through the black wire. The ground is located below the rear hatch striker. You need an EVTM.Last edited by bravekozak; 10-17-2016, 07:48 PM.
Ok. May be stupid question but where is the ground for that at?1990 Red Festiva STOCK "pregnant roller skate"
Ok. I will check for that ground tomorrow and see what it's doing. I checked all the wires with test light at the sender and I'm getting nothing.1990 Red Festiva STOCK "pregnant roller skate"
If makes any difference at all the temp gauge doesn't work either. I was trying fix one at time but they may go hand in hand not sure.1990 Red Festiva STOCK "pregnant roller skate"
Do NOT use a test light for the sending unit, it's a resistive circuit, not a power circuit. Imagine having power run through the coil and one of the windings break and then arc over...
Test with a DVOM. (Volt/ohm meter)Trees aren't kind to me...
Ok I will do that tomorrow. I'll will post results.1990 Red Festiva STOCK "pregnant roller skate"
Yes, that does make a difference. Don't waste your time testing for ground. Both grounds are separate.Originally posted by 90fastiva View PostIf makes any difference at all the temp gauge doesn't work either. I was trying fix one at time but they may go hand in hand not sure.
Check your METER fuse again. If power is passing the fuse, then the problem is inside the instument cluster (or, hopefuly, just a loose connector to the back of the cluster).Last edited by bravekozak; 10-17-2016, 09:52 PM.
So there is a chance I'm in need of a new cluser? That may have to wait for a bit.1990 Red Festiva STOCK "pregnant roller skate"
So I do think it's the cluster. I'm getting resistance readings at the sending unit.1990 Red Festiva STOCK "pregnant roller skate"
Do your blinkers work? I was having the same issue but my blinkers didn't work at the same time and it ended up being that I accidentally unplugged the connector going to the back of the cluster."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Yea. All blinker work. Something funny this morning tho. I believe something is grounding out. If I get on brakes with no lights on my cluster will light up and front parking lights. Once I get off the brake they go out. Everything else on car works like it's supposed to.1990 Red Festiva STOCK "pregnant roller skate"
