Mark the gentleman with that good looking Truckstiva at madness has a problem, him and I swapped out B3 engines in his pickup before we came to madness, once the swap was done and the car running good we were ready to head for the coast but the truck had a check engine light come on and it was not on prior to the engine swap. I did a code check and what I got was 1 long flash and no short flashes, the odd thing is my manual calls the code an intake air temp sensor, do the Festivas actually have this sensor and if so where, I have changed the VAF with no luck.
What are your thoughts and or ideas.
Thanks sc72
Thanks sc72
