Electric Issues
  • Electric Issues
    Just got a 1993 Festiva that they claim run when they parked it. The Fuel guage does not show any fuel I put 2 gallons in and the fuel pump is not pumping fuel Not getting power back to it.The fuel reset button is ok but no power to it ??? any Ideas where to lookbadh2
    Thread 58953
    Thread 57914
    Thread 58907
    Thread 58322
    There are lots of other threads. Just use the search box.
    welcomsign
      Vince, welcome to the forum. It's good to have another local member. Wish that I could help you, but someone will be on soon with some help for you I'm sure.
        The harness ground for both these closely related things is inside the car vertically below the rear hatch striker- I would start by making sure that it's grounding on clean metal there.
        Then at the assembly under the floor behind the drivers seat- check for power there, how ever you do that.
          How would checking for power at the auto seat belt module show that there's power to the fuel pump?
