Hey fellas first off sorry for the long post. Second sorry if this has been covered but i have been searching quite a bit through the help of google and cant find the info im after. my internet isnt the best so i get limited results at the moment. i hope ive not overlooked anything obvious. But anyways im new here but ive crept this place for some time now. i have 10+years in automotive and fabrication/ blacksmithing experience so i plan on doing quite a bit of fun things with this little car. ill get some pics up of it when i get back to the house. and as a side note i plan to do a weber carb in the future but for now i want to see how much improvement i can squeeze out of it with what it has. ive owned 3 festivas now, my first one was a 174k mile carbed one, my second was a 91 model fuel injected with 140k and now i have a 249k mile 1989 carbed one again. i cant believe how much stronger the carbed ones seem to feel compared to the fuel injected one i had. The first carbed festy i owned had been messed with by a previous owner. he had deleted the emissions stuff off it and plugged some of the nipples on the carb and it ran like a cut cat. Now besides that im constantly reading or hearing folks say, oh yea i got rid of all that vacuum spaghetti mess and caped it all off. never ran better.. So naturally im trying to do my research but i cant seem to find any documented info on what all can be removed with out screwing things up and what should be left alone. This has kicked up some curiosity for me because the one i have now runs ok but it definitely doesnt have the pep that the first one had and im thinking it could be all these vacuum systems it has. not that it has them but in prob 250k miles they are clogged up and probably not working properly. So from this point i started by doing away with the EGR tubes (i know thats not exactly what this system is called but im using egr because you know what im talking about) and the set up on the intake. that actually smoothed the running of the car quite a bit surprisingly. and then even more surprising when i decided to take apart the mechanism that came off the intake, i found it wasnt filled with sludge but it was dry and extremely corroded like chalky rusty lookin corrosion and half full of sand... yes sand... i dont get it either. next i pulled out the charcoal canister and the bottom of it had foam that completely fell apart when i touched it. then i could see the material behind the screen was a complete mess also. i put the canister back, it was more of an inspection than a removal attempt.
From this point id like to know what i can remove from this car that isnt necessary. ive got a haynes manual for the car and its been an invaluable resource.
The question i have about my horn is where is the relay located? the horn was missing on my car so i bought a new one. hooked it up and nothing. i checked the steering wheel buttons and all was well there so im thinking my relay is bad or something. but where is it!!??? lol
Thanks for looking and again im sorry for the long post, im bad for trying to info pack my posts. i like to try to cover all bases to help eliminate questions before they are asked lol
