92 ff manual trans, it will occasionally act like it doesn't fully go into gear.
  • 92 ff manual trans, it will occasionally act like it doesn't fully go into gear.
    The car feels like a combo of it not go into gear fully and almost like it broken ujoint . If I drive it then it passes and it shifts like normal. The pain of it is that it seems to happen when I have driven it a distance and it has only done it three times in the last year.
    Check that the linkage bolts are tight underneath the car? Check fluid level.
    Anything else out of the ordinary happen those 3 times it wouldnt go into gear?
