'93 festy...worked a few days ago;today not working.checked meter fuse...blown and replaced.still nothing.any ideas anyone?thanks in advance.
turn signals stopped working
The bigger question is what caused the fuse to blow. There's also a turn fuse. Check all and then the 3 main fuses at the driver strut tower. Corrosion can cause issues.Trees aren't kind to me...
Here is a link to a manual that might help you. Says 1991 but really no difference in the signal lights.
http://www.slideshare.net/JonathanLe...dfestivamanual
Like FestYboy says.. about 7 out of ten time, the problem is corrosion somewhere usually at the front bulbs. Remove the front lens covers and pull out the whole bulb unit and clean all the corrosion from the wires and bulb holder.Last edited by 1990new; 11-27-2016, 05:16 PM.
