Anti Syphon?
  • Anti Syphon?
    So I want to drain my tank of petrol & was wondering if our economy boxes scimped on the anti syphon feature to save a penny. Any help is appreciated
    Send An Invite If Ya Want
    1991 Ford Festiva GL- Auto
    I know that there is a connector in the engine compartment that you can ground out and it will turn the fuel pump on so that you can just disconnect the fuel line and run it into a Gas can. Just make sure that you don't burn up the fuel pump by running it dry.
      I believe that there's a drain plug on the bottom of the fuel tank.
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        There is
          Yup. Actually it's a black connector with the female spade connectors situated in a "T" configuration. Simply jumper the 2 female terminals and turn on the key.
          IF it's a stock tank it should have a drain plug towards the driver side. I'm thinking it's a 17mm, but I could be wrong.
            Awesome guys thanks alot both are cheaper than buying a syphon kit from HB Freight lol
