flywheel input shaft bearing loose
  • flywheel input shaft bearing loose
    E-series 5 speed. New "Brute Force" flywheel, New "Exedy" clutch kit.
    I have a loose condition with my input bearing. I can pull it out of the flywheel by slipping my finger into the inner race and the whole bearing pulls out smoothly. I tapped the old bearing out of the old flywheel and I have the same condition. Is this normal? I am thinking of returning it to rockauto for a replacement. Thanks
    That bearing cartridge is a compression fit, about .001-.0015 interference, and needs pressed in. Verify the hole on each flywheel is the same, then chuck the new bearing at the company that manufactures it.
      That's what I figured but wanted confirmation.
      I could have been more clear though... The new flywheel has a slightly larger hole where the new AND the old bearing have poor fit. I don't have a way to measure it with proper tools though.
      The brute force flywheel will be sent back to rockauto today. Hope the replacement is better.
      Thanks again
        Ah, then I would say it's a machining fault for sure.
          To follow up...
          Rockauto gave me a replacement warranty part (they payed shipping both directions). Same "Brute Force" flywheel, same problem. This flywheel is the most expensive one they carry. I ordered it more than 6 months ago so I can't return it for anything other than warranty, so I am just out of the money. My own fault!
          I did however order a "Luk" flywheel from them and the bearing from the "Exedy" clutch kit has a nice press fit condition.
          I am happy to finally be moving forward on this project.
          "EDIT" Rockauto has agreed to credit me toward the defective flywheel
            Good deal.
            Side note: never been happy with the fit/finish of any Brute Force product.
              You have company now
