Power braking works best (please use reverse, in an open area, in the dark)
Automatic festy hesitates .....
I'm going to try that again, but I'm going to jack the front end up and try it. This is driving me insane, I have replaced everything I can possibly think of and it's still hesitating up the hill where I live, & it stalls out too.Originally posted by FestYboy View PostDid you play with the throttle while spritzing? You'll rarely catch spark leak at idle, there needs to be a load on the engine (like blipping the throttle, or having someone power brake it).
This is what I have done so far.....
-replaced cap and rotor
-wires & spark plugs
-air meter
-fuel filter
-checked fuel tank = clean.
-checked for power loss = ok. I will check again.1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
Mike
Here's what the Haynes troubleshooting section has for "engine stumbles on acceleration"...
1. spark plugs fouled
2. problem with fuel injuection system
3. fuel filtre clogged
4. fault in the engine control system
5. intake manifold air leak
6. EGR system malfunctionOriginal owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Originally posted by rap View PostHave you checked vacuum lines for leaks or cracks? I always try checking cheapest things first & sometimes I get lucky.I will also check into some of those too, thanks!!Originally posted by WmWatt View PostHere's what the Haynes troubleshooting section has for "engine stumbles on acceleration"...
6. EGR system malfunction1993 Ford Festiva L blue 170,000 miles
Mike
Just come questions to try to trigger something:
Does it do OK backing up the hill?
Is the transmission kicking down?
How does it do when you shift manually to 1st.
Does it have a cat? Clogged going up hill?
Does it act the same way when the tank is completely full?
Any difference when the engine is cold vs hot?Last edited by 1990new; 06-24-2017, 07:58 PM.
As a last resort, try swaping in a borrowed ECU, at this age, sometimes a board will have cracked solder joints. Not common only found two bad in last 3 years.Last edited by Dragonhealer; 06-24-2017, 08:11 PM.No car too fast !
-It does the same thing backing up a hill.Originally posted by 1990new View PostJust come questions to try to trigger something:
-No tranny is not kicking down.
-its an auto. I've tried 1st and 2nd gears also. Same thing.
-No cat. It has a fairly new exhaust system.
-Acts the same way when tank is full. When tank is quarter tank left it also hesitates from a stop.
-No difference hot or cold running.1993 Ford Festiva L blue 170,000 miles
Mike
