I am working on my suspension today and a part of that is getting new lower control arms/ball joint ect...
I read a lot of previous posts about the control arm bolt just spinning after you break it loose. A lot of people had to resort to cutting a hole in the frame to stop the nut from spinning.
After reading all of these posts I decided to get my propane torch on the hidden nut for a couple minutes through the hole in the frame before trying to remove the bolt. I then gently and slowly applied my breaker bar to break it loose the bolt and backed it out with my wratchet, and it came right out. Hope this helps someone in the future.
