The dome light comes on fine when passenger side opens but drivers side she won't. It is usually a sticky button but this time in the 88 it is something else. Just wondering if there are any quick fixes I don't know about. Or do I have to search for a loose wire? Thanks
Dome light tricks....
Pull the 2 Phillips screws, and take a wire brush to the back of the switch. Also clean the 2 screw holes as they are the ground for the switch.Trees aren't kind to me...
I've had great results with this aerosol electronic cleaner. One of its most recent uses was on a stubborn door switch for the dome light in my 88L. The switch works 100% now, with no disassembly necessary. That was the next step, but I always start with the simple methods first.
Well I took the two screws out and took the switch out and that thing is clean as a whistle. I still took it apart and cleaned it a little, same for the screws. No go. Something else going on I guess. Like I say, the passenger side works fine.
