Ok, so I have some codes on my 1990 EFI auto and I've tried a bunch of stuff to fix this.
Basically the engine runs great idles great, just bucks (misfires?) under heavy acceleration until I let off the gas, gets pretty violent if I keep my foot down lol.
Usually in 1st gear but it's happened in 2nd gear.
Used to be a intermittent but now it's constant.
Codes:
Flashes code 09 (coolant sensor) at first but then doesn't repeat it.
02 CPS (replaced disty no effect)
15 o2 sensor
17 o2 sensor (replaced no effect)
Also replaced fuel filter and cleaned/tested injectors. Newer fuel tank and pump.
Spark plugs look good. Timing good.
Out of ideas. Any help is appreciated!
Codes:
15 o2 sensor
