How to remove Ignition lock barrel?
  • How to remove Ignition lock barrel?
    Has anyone removed the ignition switch? I need to replace mine. PO broke off the key in it. I have the turquoise service manual from Ford, but it doesn't say much.
    Thanks guys
    A mechanic knows how; A technician knows why.
    Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
    Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
    Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
    FB Festiva page: Jared Bennett
    Instagram: jaredbear82
    There are two screws that have round heads. I cut grooves with a grinder so I could use a flathead screwdriver. You can see them in this picture.
    1990 L Plus Stock B3 automatic -scrapped- My First Festiva - RIP
    1991 GL - B6d, g-series trans, aspire brakes, Advanced Suspension coilovers, Miata 7 spoke rims, '98 Prelude seats, more to come!
    2005 Focus ZX4 SES - purchased from original owner, my grandmother. Currently my wife's daily. 210k
    You can follow me on instagram @twfodor
      I've been able to get 3 of them off just grabbing the heads with needle nosed vice grips, and then replace the with hex head screws.
      "Wenona"-89L parts car
        I've tried needle-nose vise grips with some success. I find that cutting a slot in just one works pretty well too; get that screw out, wiggle the clamp, and the other one comes out pretty easy with needle-nose pliers and fingers.
          If you have a spare key maybe you can extract the broken key by saturating it with lubricant and teasing it out with wire, pliers, or magnet.
            Thank you all for the speedy replies. I'll try it some time between now and Sunday and check back with how it went
              It is important that the bolts be installed with the proper torque. Shear head bolts are used by the factory. The top part of the bolt breaks off when the proper torque is attained. The shear head bolts are used as a security measure to make cars harder to steal.
                You might also try using two paper clips to fish that broken key out.
                  A week late, but I got the jammed lock off. Spent about 30 minutes with a hack saw because I forgot to bring my cut off wheel. New one is coming off tomorrow
