Remove fuse panel
  • Remove fuse panel
    Doe s anyone know how to remove the fuse panel inside a 92. There are two screws that I took out and a bottom nub that seats everything. I can get the whole panel to move back and forth but I do not know how to remove it.
    Thanks for any help.
    1992 Ford Festiva 1.3 L 4-cylinder
    Push it back. Wiggle it a bit. I think you lift it up and push the bottom back first
      Thanks so much for the help. So to remove it do you push it totally back down opening or do you pull it out through the opening.
        It goes towards the firewall, then when its out you can pull it down to by where your feet go to work on it.
          Ok. Thanks again for your help.
