Hello I'm Adam and any help I could get would be much appreciated. I have a 1989 Ford Festiva L with a 4 speed manual tranny in it. Car suddenly died a week ago. Suspected fuel pump so I checked the carb to see if fuel was being delivered. No fuel was going to carb. While waiting for the fuel pump to arrive I tried to restart the car. Twice after waiting a day or more it started for no more than 2 seconds (that's a side note) fuel pump arrived and I replaced it. Fuel now is entering carb. Tried to restart and it would not. Suspected the ignition coil. The ignition coil resembles a big AA battery or an old school squeeze ketchup bottle. There is what looks very similar to a spark plug wire that runs from the top of the ignition coil to the the distributor. I unhooked the wire from the distributor and tested for spark from the distributor side groundining on the negative battery post at night and saw no spark when turning over motor. I went to autozone and they were able to give me a universal 12v ignition coil. The universal matches the one that was in there almost exactly, only difference is about 1/2 inch in height. I hooked up the new coil and tried to start. Still no start and no spark coming from the distributor end of the wire when I ground through negative post on battery. I removed the distributor cap and and examined a plastic price with metal tabs that pulls out from the center of the distributor cap and I can see no Visible problems and the distributor cap looks fine also with no obvious cracks or holes. This is were I'm at. I'm frustrated and confused. The week before it broke down I took a 200 mile round trip through the mountains and Steve (Steve the Festiva) ran like a top. I averaged 38.8 miles per gallon and not a sputter hiccup or any issues. Opinions? Suggestions? Thanks for taking the time to try and help me out. Cheers,
Adam Sprague
458.212.1522
Southern Oregon
Adam Sprague
458.212.1522
Southern Oregon
