Background:
91 bp+t w/ stratified auto mspnp
Car sat for 2 months and when I went on a short 'cruise'. When I got back, battery was dead, so I charged it up and no start. Cranks, but no start.
What Ive done already:
checked fuel pump through the connector in engine bay. works
check for spark. no spark
check compression. 140, 180, 150, 180
checked all fuses in car. good
checked fusible links (pal fuses). looked good but haven't replaced.
replaced fuel pump, fuel relay, coil, and distributor.
also, reflashed the MS ECU. works fine and connects to laptop (tunerstudio) when power is supplied by wall wart adapter in house, but doesnt connect when on car power.
So I'm thinkin something to do with powering the MS maybe? what else can I check to make sure the Ecu is getting power from the battery?
Any help is appreciated.
