Couple weeks ago I changed drugs and strut mounts. Today I checked camber and it is at +2.5
So I took the strut out and rotated the mount 180 degrees and the resulting camber was... +2.5
It seems to be fine up on the jack stands, but once the weight is back on the tires it trends positive. Wheel bearings show no sign of trouble and when twisting the tire at 12 & 6 o'clock there is no movement. Same with 9 & 3 there is no sign of slack or movement.
Any suggestion, and is it anything to worry about?
