Battery shorts out when key turned to start
  • Battery shorts out when key turned to start
    TL;DR version because I'm in a hurry...
    Motor blew, put new one in, drove it for about 3 days, motor stalled, wouldn't start (would crank, no start) for anything.
    Tried plug wires, disty cap, etc. Gave up. Car sat for ~4 months. Went to try starting it, fired right up. Idled for about 10 minutes.
    Push clutch in, put it in gear, let clutch out, died the second it started to bite (no, I didn't stall it, I know how to drive.)
    Ever since then, the battery shorts out every time I turn the key to start. If I charge it or let it sit long enough, I can turn it to accessory and all electrical works.
    But once I turn it to start, everything dies and the dash lights are instantly dim.
    Tried engine ground wire, no dice. Even doubled them up. Haven't tried anything else yet. Thoughts?
    1990 White L-Plus 5-speed rust-machine
    Scrapped
    1991 Blue L 5-speed
    daily driver, intermittent project
    1993 rustless wonder
    A shell, awaiting suspension, brakes, and B6T
    Inspect and clean the starter connections.
    If still a problem, check your ignition switch.
    If still a problem, change your battery.
      I'm with Brave, it sounds like the plates are sulfated and can't handle the current draw.
        If its not a maintinance free battery check the liquid level. Or try a different battery
          Tried jumping it with a marine battery, it worked. Gonna check the alternator to see if its out (2 year old 85A MPV alt), and will get a new battery.
          Scrapped
          1991 Blue L 5-speed
            This sounds like the exact issue I am having.
