I'm not sure what the question is. Speaking of compression numbers my B-3 fuel injected with about 175K miles has the following compression #1 165 #2 165 #3 125 #4 150. I would consider it wet compression as it is currently together and driven daily. Does that answer your question?
By "compression testers" do you mean individuals who do compression tests on their cars? Yes some have posted compression readings. I did mine last summer. The exact results are out in the car but were in the range 187-190 across all cylinders. Could you let us know more specificly what you need to know?
