So I go out to the car one day and the battery is dead ok so I charge it and check if it's holding charge. You can watch it slowly die with a multimeter .1 every 2-3 seconds so I check the system drain and it's at .03 milliamps .06 if I have my underglow on stand by
I checked each fuse and all of the .03 is coming from the ROOM fuse is this interior? Also my dash isn't in the car so what could be draining it 🤔
Sent from my XT1585 using Tapatalk
