Daughter came by ,went to leave andaspire wouldn't start ,it turns over & is getting spark but no fuel . I checked the inertia switch it doesn't seem to be popped.i pulled the fuel line off from the fuel filter under the hood very little gas came out.with key turn to on position and in the cranking position none came out . What's my next move ?
Fuel pump ? 95 aspire
Pull the inspection cover under the rear seat and check for power while cranking.Trees aren't kind to me...
