Hey guys, I am stuck and hope someone can help. I just bought 2 1993 Festiva's they both had been sitting for a few years, had to have a module on both one cranks up and runs good the other has us stuck we have no fire on the plug or coil wire, we went by the repair book and checked everything it said with a test light and an ohm meter. The plug that plugs into the distributer should burn bright on 2 of the terminals when checked but they are both real low one you just barely can see. So we are stuck and don't know what to do for it to get the power it needs, has anyone got ant idea's of what it could be. Thanks Granny
Help please
You need a DVOM and then trace the wire, probing it untill you get battery voltage. Only the black with white wire should have voltage when unplugged from the coil. Check all your fuses as well.Trees aren't kind to me...
May just have a weak coil. Did you DVOM the coil windings?Trees aren't kind to me...
Thank you, we just this evening got to check the wires with a DVOM we had to take the fender off and where the wires were put together from the factory they were loosing fire but we finally got it to crank. Thank you so much. Now i am trying to find a place where i might can order a float for the fuel pump. But again thank you.
The float itself can be had from several Mazda vehicles, however the sending unit is Festiva specific.Trees aren't kind to me...
Should be able to find a million 323 protege's in your local junkyard. That should get you a working float. Also, 2 door aspires use the same tank, so that's another option.Trees aren't kind to me...
