I'm actually evaluating A/C problems on a Hyundai- but thought I post a question or two here-
In general- can an a/c clutch be serviced or replaced on a compressor without removing it from the car and/or draining the refrigerant?
It seems like the clutch kits are pricey and it may be better to just replace with a new or rebuilt compressor- any opinions?
There's a grounding screw on the top- I think- I intend to clean but not giving it all that much of any chance of solution
I bought the car last summer- the a/c worked though not super cold- this spring it does not blow cold- tried adding refrigerant with little effect-
I put in a can of PAG oil- only 1 oz oil and two ox of refrigerant and another can of R134- it seemed to kick the compressor in gear-
it was cooling great- but did not cool down a few days later- and hard to evaluate even in Florida due to cold days-my first impression was that it was a leak
after that I put more charge in- another can of PAG oil and a can of Stop leak-and got a nice cool again that did not last-
with a warmer day today I got out there with art of the last can remaining and the gauge attached and it seemed to be holding pressure at between the green and blue lines on the can- so it may not be a leak-
but a faulty clutch on the compressor or ????? The a/c has worked great- better than last summer for two short periods this year now after adding stuff, and there seems to be fairly good pressure in the low side. I might suspect a relay or electrical problem if it didn't cool sooo well after 134 and separate (small quantity) of PAG oil.
I'm going to use another gauge and test again tomorrow- had to stop for darkness tonight
If I order a compressor, do you think it would be good to replace the line hoses and o-ring for another &60 or so in parts at the same time?
Thanks in advance, and for the cause, right?
