They're getting thin on the ground - few if anybody make 12 inch tires at all anymore.
And I DO NOT want NANKANG tires under any circumstances, I don't trust them.
In 2006 and 2007 I was working as a tech at an RV dealership, and we found fraudulent date of manufacture markings in the DOT stamp on the sidewalls of almost all the NANKANGS we looked at (post-dated into the future) At the time, a lot of RV's were having highway tire failures that caused huge damage to RV sides when Nankang tires just BLEW UP at freeway speed.
I found one that was dated as having been molded in the year 2011 - which was five years in the future!
I'll shell out for Yokohama's or Coopers before I risk my butt on them ever again.
Basic size is 155R12, and may cross over to 155/60R12 or 155/70R12
I'm looking for a cheap set of wheels and tires to serve until I upgrade to 13 or 14 inch rims with low profile sidewalls
ODD thing this: If you do a make, model, and year search on most tire sites they will say "Sorry! Nothing we have fits your car"
But if you do the search again and specify a classic Mini (as in Austin Mini Cooper, which also has 12 inch rims) all of a sudden they list a bunch of tires on 12 inch rims
I found a couple on Amazon with free shipping that are 155/80R12, speed rating "T"
The tread to tread diameter is 21.5 inches
Tire Rack also has 155/80R12's by "CLASSIC" load range 77, speed rating "T"
(900+) lbs per tire, 118 MPH) for approx. $55 each
Yokohama also has them, but @ $89 per tire
All I need to verify now is that 21.5 inches diameter is not "OVER" what should be put on
*Tall sidewalls cost fuel, but prevent bent rims and embarrassing "STRANDEDNESS"
