I recently pulled an engine out of a 94 Aspire for my Festiva, but it wasn't until I put the Festy distributor in that I realized the crankshaft pulley was missing its timing marks. I can find tdc but is there any way to remark the pulley?
Missing timing marks
There should be a notch in in the pulley. It comes from the factory with a dab of yellow paint in the notch but that may have fallen off.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Pull spark plug #1 out. Put a long rod in. Spin crank with a wrench till the rod is up all the way. Thays tdc. Thats you 0°. Mark the pully and time from there.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Just use a paint parker and or a punch. Or a knife. Just gotta make a scar on the surface.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Mike is right but I think you might want TDC on the compression stroke? For that you may need to take off the distributor cap and check that the rotor is pointing to the #1 spark plug position? Not sure about this.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
TDC is TDC regardless of the stroke. Remember, the crank rotates twice per cycle.Trees aren't kind to me...
"TDC is TDC regardless of the stroke. Remember, the crank rotates twice per cycle."
So the pulley rotates twice but the plug and timing light only fire on one of those two rotations which means the timing mark is illuminated on every second pass?
If I understand that right TDC stroke doesn't matter for checking timing but does for adjusting valve lash?Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Thats how mine is as well. I just found tdc and took a knife to the pulley then painted it white. good as new now.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Correct mechanical timing is achieved when the crankshaft timing mark is straight up at 12 o'clock and the camshaft timing marks are at 12 and 3 o'clock. Your timing belt should be installed at these settings and the #1 piston is at TDC.
Sent from my iPhone using Tapatalk"Fred" 93 Festiva L B6-ME Swap
“Though he is small, he is but fierce.”
Now this engine is doing the same things that the old engine was doing, specifically the idle is garbage and it bogs down when you open the throttle, but surges when it's closed. The only thing that came with the new engine was the block and headband so I reused most of the old engine stuff. Any ideas?
Yes, but only when looking at the correlation between crank and pulley timing. As for actual ignition timing, all 3 things need to line up (cam, crank, and pulley).Originally posted by WmWatt View Post"TDC is TDC regardless of the stroke. Remember, the crank rotates twice per cycle."
Krock26, you say there are no marks on the cover? There should then be evidence of the tab that has the marks having been cut off. There are 2 marks cast into the valve cover to set cam timing so if the crank and cam line up, in theory you could pick an arbitrary mark to set ignition timing.
A while back I was informed about a condition of some aspire cams being timed incorrectly via the dowel pin location. You may want to degree the cam to verify its correctness.Trees aren't kind to me...
