Originally posted by krock26
Missing timing marks
I actually found a rubber intake in pristine condition at a junkyard so I know that there are not leaks there. I used propane to track down leaks and I found one, but I patched it so it's not leaking anymore. It's almost like the timing is off but I made sure the belt was on exactly right and playing with the distributor doesn't fix it. I'm starting to suspect the ECM but I just don't know.
Compression test...Trees aren't kind to me...
Does the pulley have a rubber core to it? Maybe its flexing when you get on it and changes the timing. Then when you let out does it again. IDK if thats a thing or not tho. Just a thought.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Fuel pressure? If the mechanical timing is good and those compression numbers are better than my girls aspire by a long shot, it has to be fuel. You only need 4 things to run: fuel, air, spark and compression.Trees aren't kind to me...
I tried bypassing the fuel pump relay but it still does the same thing. The VAF was taken out of a running car and I've replaced the coolant temp sensor, fuel pump, fuel filter, coil, cap and rotor, wires and plugs and TPS. I tried buying a new computer but it was a bad replacement and failed after a hundred miles so I'm back on the original one. I messed with the idle screws before I found out that that was a big nono, but that shouldn't make the car big down when I'm at WOT. I don't know what it could be besides the computer, distributor, ignition control module or O2 sensor. I'd rather not throw all those parts at it if I can figure out exactly what it is.
Ok, let's back up, and list all the issues.
Earlier I'm the thread you mentioned crappy idle, a bog at tip in, and surging once the throttle is closed. Now there is also bogging at WOT. At what RPM do these issues present themselves? (Besides the crappy idle). Are we absolutely positive the cam isn't off a tooth? Where is the dizzy in relation to it's adjustment slot now? Is the engine grounded well? Have you done a spark leak test?Trees aren't kind to me...
Here's a video I made of what it does, sorry for the bad quality: https://youtu.be/AziZT0uzWZU
Once it gets above 2000 rpm it has a normal power and but under that it's all sorts of messed up. I double checked that the timing marks line up on both ends of the belt. The ground wire on the passenger side looked iffy, I can try making a new one to see if it does anything. The distributor is about in the middle of its slot and I haven't done a spark leak test.Last edited by krock26; 03-21-2017, 11:56 PM.
Ok. That is not the correct procedure to set the TPS. Follow the procedure in the Haynes manual or whatever manual you have. The procedure requires the use of a feeler gauge and OHM meter to accurately set the TPS. If you did tamper with the dash pot screw on the passenger side of the throttle body, that will certainly affect the TPS adjustment.
Sent from my iPhone using Tapatalk"Fred" 93 Festiva L B6-ME Swap
“Though he is small, he is but fierce.”
I'll look for my post on how to set it...
Found it: http://www.fordfestiva.com/forums/sh...tment%2C+plate
Post #10Last edited by FestYboy; 03-22-2017, 11:08 AM.Trees aren't kind to me...
When you pull the head, carefully inspect the valves and seats for burn through.Trees aren't kind to me...
