'92 Festiva GL, stock brakes if it matters.
I'm having this issue where once the front brakes warm up from driving, they drag. It's enough that you can feel the car struggling to keep speed in 5th gear. I've noticed that they eventually free up enough and you can feel the car gain speed again until I have to slow down for a stop, then it starts all over again. The wheels spin freely when everything is cold, with a slight drag from the pads you can hear, which seems common from my experience. After searching here, I thought it might be the slide pins. So yesterday I tried disassembling the calipers completely. I cleaned and greased all four slide pins with high temp grease. I also removed the pistons and cleaned any roughness from them and made sure the seals were in good shape on both sides. I then bled both sides, starting with the passenger side. When I got to work this morning I could smell the brake pad "aroma" in the air so I knew I still had an issue, but no time to mess with it. After I got home from work tonight and had more time, I immediately jacked it up and they definitely don't spin as well as when they are cold. I also couldn't touch the front rims because of how hot they were. The rears are cool to the touch and spin very easily compared to the fronts. (I've already reworked the rears due to the common issue e-brake sticking.)
Does anyone have any ideas? What am I missing?
