So I have had this "issue" more or less a thing I have noticed that happens sometimes. Most notably when I am going up this on-ramp that is a 180 turn, I either down shift to second or am already in second. When I then apply gas sometimes I feel very prominent "fuel cuts". I put this in quotes because I don't actually know what exactly is happening, all I know is that my car definitely stops getting power.
This happened with my stock engine and it's happening more often now that I have a bp engine. If I had to guess I would think it's the exhaust because that is one of the few things that is still stock.
Just for some more examples out of my neighborhood there is a 90 degree turn onto a 4 lane road. I will be driving in second and, when the light is green and there are no other cars around, I like to hit it around that turn. So I'm cruising going straight, approach the turn giving light gas and harder as I go into the turn, by the time I'm at the apex I'm pushing the gas down until I'm flooring it. Then revs go up-then lag/cut in power.
I thought maybe it's because I'm going from no pedal to the floor? Or maybe I'm going to too low of a gear in high rpms, I have no idea really because I have no tachometer, just sound lol.
I wanted to experiment and right out of my work it's a yield turn to get up to 55 and most of the time there are no other cars so I like to take that turn fast. Im flying up to this turn, enter, and when I start accelerating, I can be in second or (less common but it happens) in third but mostly in the mid-higher rev range there is a blatant stop of revs as if I completely let off the gas with the car in neutral. So this morning, since I thought it was because I was flooring it, I gradually increased the revs where I would normally would be pushing harder/flooring it. Still happened.
I'm pretty sure this is an exhaust problem and that's what you guys are going to tell me, but I also have some trivia questions to go along with this!!
Not only what is the problem, but why is this happening, I'm curious! Like if it is my exhaust, why is it causing this to happen? Why will a new exhaust, or whatever it is, fix this?
Then, of course, what are some good solutions to this issue? Obviously fix it, duhhh idiot!
Thanks!
Thanks!
