So at Westiva i was able to drive Ben's car Frito and tried it's a/c. It blew colder than mine and harder. Harder because i have a cabin air filter. I had brought along the same thermometer i checked my cars a/c temperature with and he checked his. Frito will get down to 34f, mine kicks out at 42f.
Then i drove Bob Kiddy's car and while i unfortunatly didnt try his a/c we started talking about it and he told me that to adjust the temperature set point there is a screw you can turn. But to turn it slowly and not far at a time or things inside will break. He did not remember which way to turn the screw for colder/warmer adjustment.
Does anyone know? Is this procedure described in a shop manual?
I will adjust mine and update this thread with how that goes but if anyone knows which way to turn the screw i would like to start in the right direction.
The screw is on the thermostat under the glovebox by the way. Here:
