5 Speed won't go into Reverse only?
  • 5 Speed won't go into Reverse only?
    Hey guys,
    Just bought a parts 1988 LX. I checked it before buying if it would go into 5th, which is fine, weird thing though it won't go into reverse only? I don't really have a clue why reverse would be the only gear it won't go into. The only idea I have is the reverse light ball is stuck maybe? Anyone else have any suggestions?
    Current cars:
    Is it the transmission or the shift linkage? By the time I replaced the shift linkage bushings on my Festiva it was tricky getting the shift lever all the way over to first gear.
      I'm going to check the shift linkages when I get it into the garage as they might be suspect but I thought it was weird that I can go into 5th but not reverse gear. The shifter doesn't feel sloppy but it has the rubber boot thing so it totally could be.
      Current cars:
        Shift linkages are tight, seems like it's internal to the transmission. This sucks because I literally bought this car for two parts: The transmission and tach cluster.
        Current cars:
