Have tried everything
  • Have tried everything
    !993 Festiva GL have tried everything but no good, I have no spark on plug wire no power to fuel pump and no power on injectors have tested it all put on new parts and still can't get it figured out any help will be welcome. Thanks
    What happened since it ran last? And whats the furthest from the ignition switch that you do have power?
      Power at coil? Also, if power out to all those things I'd suspect a fuse somewhere. What about those fuesable links on the shock/strut tower I've read so much about here?
        Check the ENGINE fuse at the inside fuse block. I'm sure you have already checked the 3 fuse links in the engine bay.
          Do you know if the distributor works properly?
          It is responsible for telling the injectors to fire.
          Fuel pump only gets power for about 1second at key-on, after that the AFM must see some air flow for the fuel pump switch to be on.
          No car too fast !
