I have a troublesome problem with the lights in my instrument cluster... they seem to have a mind of their own and don't want to come on most of the time when I turn on the headlights. Here's what I do know:
Any ideas? I'm going to pull the cluster and check for tight connections to see if that's an issue. Will also check for cracks in the circuit board.
Thanks
- the bulbs are good because they do come on occasionally
- the headlight buzzer works (the one that lets you know you've left your lights on) so I know there's power getting to that circuit even when the cluster lights don't come on
- all other parts of the cluster are working as they should
- when they do come on it seems to be on hotter days
Thanks
