Shaking
  • #16
    Originally posted by sodakfastiva View Post
    My tie rods aren't perfect but they are tight. The rubber is cracked and split but tight for sure. For tires I am running 175/65R14 - Ironman RB-12s and they are brand new. I did order the sway bar to LCA bushings because they were under 2 bucks.
    Use HUBCENTRIC ALUMINUM RINGS to fiil the clearance between your hub and your wheels ( 59,6 mm is the hub size )
    • #17
      Thank you I forgot about that too, I will get some rings and see if that helps!
      93 Festiva B6 5spd
