Hey guys I've got a 91 Festy, all stock with the 1.3L. I apologize if this is posted somewhere else and I didn't find the info I needed; maybe someone else with better forum navigating skills could easily find something about this.
So I recently tried installing a tachometer by running the green (signal) wire soldered inline with the negative wire off the ignition coil (yellow/green wire I think?), black/ground to the post that holds the wiper arm motor to the firewall (it grounds the wiper motor itself so I assumed it should be a fine ground for this) and I was trying to find a good switched power source under the hood. I found a wire that was hanging loose in the engine bay with a female spade bit already attached, and it had switched power. Perfect! So I thought. I plugged it all in, and the engine seemed to drop its idle a few hundred RPM when I plugged in the power source, and the previously tested good tach was flashing all digits very faintly. It took me a minute or two to realize that the power source I had chosen was probably a timing freeze circuit that you ground out when setting the timing so it doesn't move around. Now, the tach doesn't work at all, and when it's hot and/or the engine warms up, it stalls when I let off the throttle from an RPM somewhere over probably 1K. The tach is still hooked to ground and signal, but not power. Sorry for the extensive backstory, but now my question is;
Could I have damaged some kind of ignition circuit by plugging the tach into that plug? Would that be causing the engine stall when throttle letoff? Or is it more likely that I just have an issue with the solder point in the negative wire of the coil, like too much resistance?
Any advice would be appreciated!
