I have just spent a month or two trying to figure out why my 1999 Ford Festiva keeps flooding after it rains. Finally I got an answer from a body shop where they spent several days trying to hose the car to find the leak. I was hoping they could remove the windscreen wipers and take of the air flow grid to shine a torch but the air flow grid is molded on permanently.
The mechanic finally hosed the passenger side of the car and told me the leak is coming from the under the dashboard on the passenger side where the air conditioner is located. The water was running through a tunnel to the drivers side. He says he has blocked the tunnel and drilled
holes in the passenger side to allow the water to drain and to just keep a towel handy to dry up when the carpet on the passenger side is drenched.
The other alternative is to remove the dashboard, the air conditioner and heater and seal the air conditioner panel and re gas the air conditioner and put it back together again at a cost of $1,500.00.
Since I am a a non mechanical female driver who really loves her car just wanted some opinions and suggestions if anyone has had similar problem.
