This is the first time I have posted on this forum but I am at a loss so I am asking for some guidance. I have a carbureted 1989 Festiva with only 63,000 miles. I bought it with 48,000 and at the time it jerked in 2nd and 3rd gears...I replaced the clutch and all ignition parts except the coil but no positive affect. I checked the timing and corrected it---few degrees out...but the jerking continued but only once in a while--usually about 30-40 mph in 2nd or 3rd gear. Today I was driving about 75 mph and the car lost power and started to jerk again...all the way to work. Later, as I was getting back home, it would not get going out of a stop without having to accelerate hard and then engaging the clutch; hesitating and bucking through the lower bands of power until it was accelerating hard but it would still buck and hesitate just not as forcefully. It was smooth when accelerating hard or when going up hill--because you have to accelerate to go up a hill. On a flat or downhill it would just buck and sputter even when I tried to regulate the speed at about 50 mph or 2200 rpm. Once I arrive home I checked the timing belt to ensure that it had not jumped a tooth in any of the cogs on the cam or crank....no problems there. I lifted the air cleaner cover, checked for fuel...no problems there--at idle. Finally, with the transmission in neutral I opened the carburetor up and found that the engine would almost die out when accelerating though about 3000 rpm and then continue strong. I am not well versed in the carburetor system and I am at my wits end with this problem. Any ideas? Accelerator pump?
Thank you,
James Harvey
New Orleans
Thank you,
James Harvey
New Orleans
